legendarybear
I just did an engine rebuild 1981 cj 7 4.2 straight 6. Not idling the best. Someone recommended I use C foam... Should I ate should I not?
Original carburetor. What would you recommend?
Well, if you don't have to keep it, a Motocraft 2100 would be what I would go with if you're on a budget. Of course, there are plenty of other carbs that you can use as well. But, if you need to keep what you have or just want to work with it, I would bypass the computer and/or rebuild the carb. Clean out the needles thoroughly as them dribbling is what's most likely causing your rough idle.
Would MC 2300 work?
Also one thing you did not mention, but assuming teh distro, cap, rotor are also ingood shape? Some of the distro and rotors out there are crappy, I would start there before doing a full carb swap, check wires etc. Also run fuel froma gas can (fresh gas) I am hoping you did not run old fuel from the gas tank
