Here's the youtube link for the video. Got some really good footage at about 14:30 to 17
View attachment 270208View attachment 270209
What are the details on your trailer? I see you built it yourself did you use plans you found online or copy another build? What are the dimensions, dry weight etc? If you had to build another one what would you change? One thing that I noticed on your build is you have no suspension on the trailer it appeared as though it was just a rigid frame???
Thank you for posting that video. Gives me a better idea as I formulate my trailer plans.
Could you elaborate on the drivetrain you are running? And yes, that is some mighty fine driving there. Looks like a blast. Kudos on recording and editing.
As far as what I would change. This one is my proto type. I've started my next trailer. I plan on fiber glass siding instead of 24 ga tin. Also will insulate it as it gets hot inside of trailer on the food and water supply. Also plan on a bigger sink. The water tank is a 10 gal. in which serves my wife and I for 5 days but we have been taking longer expeditions so I will be going to a 15 gal so we have enough for a couple of showers too. I do have hot water on demand with an outdoor shower but haven't used the shower yet. The Tepiu tent is a great tent but the pvc cover is a little to tight and causes zipper issues. So I will try out the CVT Summit RTT this time as their pvc cover is larger. I've designed the plumbing to utilize the water pump to also suck water from a creek to the tank for refills while out in the wilderness on the new trailer. I plan on adding a 200w solar system to recharge the deep cycle as I am adding an electric freezer/refrigerator. As the trailer stands I have used it alot in the last 2 years on original charge of battery but with adding the electric frig it would only last about 40 hrs before needing recharged.
