Jeep10
To set the stage on my installation, I am working on a 2010 Wrangler Unlimited Sport. I previously installed a complete Rubicon Express RE7143 3.5" lift, RE Sway bar disconnects, and RE upgraded track bar. I also have Synergy PPM-8002 JK Tie Rod. My goal was to install the new Rubicon Express RE2621 High Steer kit which is design to help correct steering miss-alignments as well as upgrade my previously bent drag link. It is designed to work for lifts of 3.5" and higher. The design for this kit is really sweet and the bracket connects to, and strengthens, the steering linkage points in with the upper control arm mount on the steering side. Once everything came in, I held things in place and had some concerns. I sent RE a note inquiring if the kit would work with my other components. The response back from them was..."it should bolt right up". Well, not exactly. The RE track bar is too long and will not allow the axle to be re-centered. To correct his problem I had to get the track bar back to its original location. To do this, because of the design of the RE bracket, you have to cut away the material on the original track bar mounting position, around outer hole so the track bar would slide back to its original position. This allows the track bar to be re-mounted back to it's original position. I do not know if these adjustments are required with stock equipment. I sent a note back to RE inquiring if I am setting myself up for further issues. They admitted that the RE track bar is too long and they were working to make one shorter. However, they did like my adjustment to correct their original flaw. Again, this set up is really nice. It is marginal for lifts of 3.5" as advertised, but would probably work well with 4" and higher lifts. I like the final product and the alignment and driving is nice. The axle is still about 1/8" off center, but it drives very nicely. I will address this later when I put the stabilizer on. I found a problem with mine, like it has an air bubble in it, so I ordered a new one. I certainly am no expert, so any advise is greatly appreciated.
