nsjeepster
Hi All
My e-locker was not engaging when I pressed the switch for the front locker. checked wiring OK ., pulled front cover on diff drained fluid and cleaned carrier with brake clean. Wires go into a locker engager which when charged, force a collar to pop out. I could see collar in center of locker engager but it would not move, with locker turned on. Used a small screw driver and pushed out collar while e-locker was on. It came out. It worked a few times once I got it loose but jammed.
Next I pulled out carrier (hint the 8 mill bolt holding plug into diff needs to be removed and plug lifted out now held in by rubber o ring and grit LOL. Then the wires can be unplugged from bottom of that piece) Once the carrier is out, the bearing on carrier on the engager side needs to be pulled off with bearing remover tool. After that, the engager is removed. What I found was a ridge of metal that was built up on collar's outside edge and on the end of piece that collar slid in and out on. The red shows the edges that need attention. These should be smooth with no ridges. I used a small file to remove the ridges on both pieces then a ton of brake clean to remove debris from all of the in collar inside and out till I didn't see any more crap dripping out .
The collar would now move freely in and out by tipping it up or down. I reinstalled collar, bearing and axle seals while it was out. ( might as well as they are easy to get at) then added royal purple fluid and put it back together and all works flawless! Wish I took pictures Sorry! Not sure if this is the case for all e-locked Rubicon JKs but it was the issue with mine so I thought id share my findings ! Happy Trails!
Ps thanks for use of pic
