jking62433
I have 02 TJ which isn't locked. Can I put rubicon axles under it to use them ?
Also a quick reminder, if you decide to put in rubicon axles you will also most likely need an oem compressor to run the lockers. It is a pain in the butt to get dailed in and you risk breaking the lockers if you try and run an aftermarket compressor. Not a big deal but something that could be easily overlooked
^^^ Huh, Rubin axles have electronic lockers stock not air. What are you meaning?
Tj rubicon axles were air lockers
