Bloodthirsty
I absolutely hate the factory system.
What's the best solution to replacing it?
Replacing it.What's the best solution to replacing it?
Can I have it? I'd be happy to pay for shipping!I absolutely hate the factory system.
Sport bar with easy disconnect and sell the rubi bar to Eddie. Two birds one stone.I absolutely hate the factory system.
You are correct. It is softer than a factory sway bar and stiffer than being disconnected. From personal experience, I can tell you that the on road ride is okay but I still prefer a stock sway bar. On the rocks, the Antirock WILL LIMIT FLEX. I have literally done an apples to apples comparison and the difference is significant, especially in the rear.Not to get off topic but how the hell does a Currie Anti Rock actually work? Correct me if I'm wrong but Its essentially a softer sway bar to offer more articulation off road (but less then disconnects) but some how firm enough to give you good road characteristics (but less firm then factory connected) I see a argument that you actually want "some" swaybar pressure off road so maybe that's the key and it looks to be adaptable to a lot of different axle set ups. Just seems like a jack of all trades master of none to me.
JK or JL? I know the JK has this sort of problem.The EVO manual is inexpensive and works great. The factory disconnect motor IMO is shit if you are in an area with alot of water crossings. I don't like water crossings because water is the worst thing for a vehicle. My disconnect motor shorted out 6 months after purchasing Jeep. When I removed and disassembled it to troubleshoot the problem, the inside of it was wet and the circuit board was shorted. Seems to me it really isn't designed to be submerged which is pretty stupid on a Wrangler Rubicon.
JLJK or JL? I know the JK has this sort of problem.
