I just installed some interior ambient lighting and will be installing Rock Lights. I don’t want to plug into the 12v socket. Any easy suggestions for rocker switches and where I splice into the 12v power? Appreciate the advice
Do you want the switches to work without the key in the ignition? When you say you don't want to plug into the cigarette lighter, do you mean that literally? Or do you mean you don't want to tap the power behind the 12 volt outlet?
I used one of these to splice into an ignition power source for my air locker compressor. I can't remember exactly but im pretty sure I spliced it into the positive behind the cig lighter.
Edit: just checked my build thread and yes I tapped into the cig lighter positive for ignition power so basically my locker compressor will not turn on unless I have the key on.
