Oh and I should mention that when I called rock krawler about the broken bolts they never called me back or later even acknowledged that I had been trying to reach them.
When I called about the bent sway bar end link they charged me full price and shipping for the replacement even though untold them the kit had 200 miles total on it.
In my opinion, f*ck that company.
I'm not sticking up for them but the sway bar link appears to be from being overextended which is your fault not theirs. And they can't charge you if you don't give them your card so again it's your fault for paying $200 for sway bar links.
I didn't pay $200 for links. I paid $7.50 plus $10 shipping. And yes, I know how they bent but for a part that is that inexpensive I would've expected RK to just ship another one no questions asked, like most companies would.
You broke it. Why should they have to replace it because of your mistake?
My biggest complaint with my RK lift is the frame side rubber bushings on the lower control arms. Total junk and don't last. I would get arms with joints at both ends like evo or currie.
Really? I didn't know that...They have a new joint on the frame side, don't know longevity, but it does ride nice and the flex seems to be there.
Couple of questions?
What lift are you currently running?
What is your budget?
What is your end goal for your Jeep?
Your profile is not filled out so starting there would help out a lot.
R/
Will
If you have no budget in mind go Evo bolt in or DTD. I'm the same way about getting the best I can, if I knew about Evo I would have went that way vs. my X factor.
I think overlandjk said it perfectly in another thread...if you wanna go fast over stuff get the Bolt in, if you wanna go really fast do the DTD. I've seen threads that the DTD is a bit more maintenance than the bolt in so if it's a DD the bolt in might be perfect.
