Anybody ever hear of checking if a engine has been overheated by checking the temper on the compression ring?
kaptkrappy said:I asked (googled) this question and there isn't a single result that mentions the temper of piston combustion rings or a reason to test for it.
If you have the engine apart and the rings off the pistons, who cares if the motor was overheated in the past. it's rebuild/re-ring time.
I'm curious, why you are asking. :thinking:
My jeep is at the dealer for exssesive, they tore it down and said that the rings had lost their temper so the engine had to have been overheated voiding the warranty, I've owned it since day one and it's never had a heating issue...
kaptkrappy said:They can't void your warranty because it overheated. (period)
They can possibly void your warranty because an aftermarket part (bumper with grille guard) or a non-spec fluid (coolant or oil) caused your JK to overheat and ruin the piston rings temper.
This sucks.
Smizar said:I must have screamed BS just enough because I just got the call saying a new short block had been approved and the heads were sent out today to be rebuilt..
