Gadget
To replace the headlight bulbs in my 14 JK with LED bulbs will I have to remove the front grille?
If people are flashing you, you need to adjust the lights better. Properly aimed, LED lights shouldn't bother anyone.Yes, but it’s really a piece of cake. Shouldn’t take more than 20 minutes start to finish. I did the same with my JK. Just be prepared for other drivers flashing their high beams at you. The LEDs are bright and everyone thinks I have my high beams on. Whenever it happens, and it happens a lot, I usually respond with a polite flash back of my actual high beams. That seems to set them straight.
If people are flashing you, hopefully they're good looking.
^ Fixed it for you.
I pulled the Jeep about ten foot from the closed garage and adjusted them from there my truck is roughly the same height so I just just that as my reference point. Now there are straight and haven’t been flashed. View attachment 315214they look amazing now. And I can see so much better now.
