Cousin Clyde
I have aftermarket double Cardan front and rear shafts. Changed the yokes on the t case and the rear pinion. Used red locktite on the yokes. Don’t regret it. Those need to stay on real good. HOWEVER, I was in instruction following mode and used red on the bolts that attach the front drive shaft to the oem front diff :doh: I need to break it off to grease, and I would like to be able to break it off on the trail to swap out a u joint if necessary. Does anyone carry a butane torch on the trail or have a better idea?!
EDIT: Thoughts on blue vs red for this application in the future...
