MattAlpha
This is what I found when I was packing my Jeep for a trip up to VT.
You can see the ground wire just hanging vice being attached to the defroster strip on the window.
So I grabbed my soldering iron, flux, a wire brush and solder and threw them in the Jeep.
This is what I did to fix it this morning.
I used a flat head screw driver to remove the button mount from the ground strap.
Here's where the mount fits onto the defroster's ground strip.
I cleaned up the mounting surfaces with the wire brush.
I then applied flux to both of the mounting surfaces and then heated them up and soldered them together all the way around. Here's the end result.
All reassembled.
Works perfectly, which is what I needed this time of the year.
Overall it took me about 20 minutes from start to finish.
I hope this helps someone else in the future.
-Matt
All reassembled.
-Matt
