Rear Track Bar
bhaner
I am looking for an upgraded and adjustable rear track bar for my 2016 JKU.
I made the mistake of ordering a Yeti for the front before I knew the history here. So I figured I would ask before I ordered anything this time.
Thoughts?
I thought the EVO kit came with a raised track bar bracket to address that... ?
I have a bracket on the frame that moves the mount point forward.
I have a bracket on the axle that moves the mount point forward and up.
Both are installed but I would like to be able to center it a little better.
I would also like to add some strength. Not sure what causes them to bend... Maybe it is the angles.... But I would rather take care of it now and not on a trail in the middle of nowhere.
Huh... Odd that it's off enough to bug you. Have you checked it fully loaded and a full tank of gas? The axle changes position constantly.
That being said, I haven't heard about many rear track bar failures and I think most here run the stocker. I run Currie steering links and just installed their front adjustable track bar and am very happy with their products so I'd probably get their rear track bar if I needed one.
I don't have a tank or much load at all in it at this point.
The ride height is adjustable and I do want to lower it down a bit.
Once I get everything installed and the tank filled I will check it again.
However it shouldn't hurt to have a better track bar.
^^^^^^ that and Currie is something I would trust.
