The BAD Influence
Since there is no way to adjust the rear toe, if it's not zero, does that mean my rear housing is bent?
Forgot to attach readings
From the center of each hubcap to what?I took it into another shop and the readings are almost identical.
Rear shafts are only a few weeks old. Tires have been rotated and balanced. I followed my wife driving it and rear tires seem to be straight, no wobble that I can see.
I measured from center of each hubcap and the passenger side is 7/8" longer. I have checked and rechecked the control arms. Each set is identical in length.
Don't know what to do next.
Ya, that didn't make sense. From center of front hubcap to center of rear hubcap. We've got the XD Rockstar wheels, so went from center point of each star. Maybe not the most accurate, but even with some variance in plastic stars, the axles clearly aren't parallel.
