2014siljk
Looking for sway bar links for front . Installing EVO leveling kit
Sent from my XT1565 using WAYALIFE mobile app
The leveling kit is made so that you don't need to add longer links up front or the rear and can be used with the stock set up.
Honestly, I waited to see what the angle was until after I installed the leveling kit. That was my preference. It was a little "flighty" but nothing to the level of white knuckle to me.
you are a marine......white knuckle to you is probably shitting bricks to me
I drove on a 2" BB with stock links for a year and it was fine. Just make sure you disconnect before going off road. The shorter links will get in a bind a lot easier. Eventually I just put some rear links up front, but only after I found the right price :thumb: $10 on craigslist.
Get them, you'll be glad you did for the 2 door.
I found mine on Amazon for cheap, I'll see if I can find the link.
When are you installing the kit?
probably in a few weeks...going back and forth about the rear with the spacers or getting ome springs also
