What shock and trackbar mount are you using? I have never seen an issue with a shocking hitting the mount ever
I had an issue with my rock krawler bracket hitting my bilstiens in the rear of my 08. I know this isn't what he is running but it's not totally unheard of.What shock and trackbar mount are you using? I have never seen an issue with a shocking hitting the mount ever
Looks like you're going to need a different track bar bracket in order to run those shocks. I would never mount the shock like you show in the first photo. One side of the shock id totally unsupported. That will very likely fail or bend the shock mount. While that may be Ok to drive a short distance in order to get to a dealer or something I would not want to trust that as a final solution.
I agree, you need a different track bar bracket
Hi,
can someone tell me wich track bar bracket will fit with the 2.5" suspension and my shocks?
You don't have mutch choise on street legal brackets her in germany.
Lg
Are you limited by installation method or manufacturer?
There are bolt-on kits as well as weld on kits available. Some of the bolt-on kits can be welded as well. I would suggest weld-on if possible. There are several manufacturers of these brackets: EVO, Synergy, Rock Krawler, JKS etc.
Quadratec has several on their site you can look at: https://www.quadratec.com/search/rear track bar bracket
Hi,
usually both. For AEV Parts, OME and JKs there are some Documents. Maybe my dealer get a bolt on kit street legal. Do you know one?
This looks like it will fit: https://www.quadratec.com/products/16315_6062_07.htm
Weld on is impossible to get it street legal. Therefore you cant get long arm suspension street legal in Germany.
Thank you!
Hi,
So?
If the JKS bracket would fit - this would be perfect. JKS is street legal her.
Thank you.
