Rear hydraulic bump stops
jkmitch
I just ordered the front hydraulic bump stops for my jk. Is it worth it to get the rears also????
I'm running a RockKrawler 2.5 right now and currently have the JKS acos pro in the front. I was just wondering if it would be good invest in the back also. I plan on going with coilovers down the road but not anytime soon. I find myself doing more and more desert ore running style off-roading than rock crawling so I'm trying to build to that.
I have both, Kings in the front and Evo's in the rear. hardest thing about both is figuring out the pressure to run, I'm still playing with that.
I have Fox in the front. 3" stroke set at 120psi. works great. Problem is my back can't keep up with the front. I ordered up the 2" stroke Fox to put in the rear. Having them welded in two weeks from now. Went with Fox because I can have rebuilt by them locally. They are a little less money too. Its this part number FOX-983-02-091
Im guessing 80PSI on the rear to start.
