B beefytank New member May 31, 2016 #1 noticed it a day ago my rear driver side brake are squeaking when am on the move then stops when I speed up and sometimes when a brake help please do I need a brake change?
olram30 Not That Kind of Engineer May 31, 2016 #3 Brakes should still be good on a 2015. Probably a rock like mentioned. Had that happen before
JAGS Hooked May 31, 2016 #4 Could also be the brake shield. The brakes themselves could be worn (miles??). Worse case is a bent flange. Have you been out wheeling lately? Ive had all the above happen over the years and it can be hard to narrow down. Process of elimination.
swampdog New member May 31, 2016 #5 JAGS said: Could also be the brake shield. The brakes themselves could be worn (miles??). Worse case is a bent flange. Have you been out wheeling lately? Ive had all the above happen over the years and it can be hard to narrow down. Process of elimination. Click to expand... Sounds like dust shield to me as well. I battled one of those last time I was at Windrock and fixed it with a prybar (Thanks MedixJK).
