Thanks for the info. I will try the big hammer, how much room do you think I have between the skid and tank?
Psr76 said:Anybody have issues with rear drive shaft rubbing on the gas tank skid? I have 1350 drive shaft and if the rear passenger tie gets stuffed with drivers at full droop shaft rubs. Axle is centered. I added bump stop spacer and it stopped but have no up travel. Any suggestions?
I have the same problem and with a 1350. I cheated my axel over about .25inchs. It seem to drive the same on the road. I haven't checked yet to see if it corrected it or not. Might need a BFH though.
The hammer didnt work for me...no leverage and not alot of "swinging" room.
It helps to pull the shaft off and then use a 3 lb hammer. Having said that, you shouldn't have this problem with a stock drive shaft. If you do, your axle is off center.
I think its my skid plate thats pushed over into the DS.
How would I fix an off centered axle?
I seriously doubt that it could be pushed out enough to make contact with a factory DS.
You would need to install a track bar relocation bracket and/or an adjustable track bar.
Hey Eddie, off topic quick question...i cracked the orange boot that surrounds the end of my RCV axle, how big of an issue is this?
Is this a part that needs attention asap?
Call RCV and they will send you another one. I would do it in a hurry and not drive too much.
