It came with the bearing seal and retainer with the for studs that hold it to the axle housing but it did not come with a collar that the OEM shaft had. It gets pressed on next to the bearing and goes inside the axle tubeDoesn't sound right to me. The bearing kit should include seal, bearing, and retaining ring
Well shit! Looks like I'll be pulling out the new shafts this week. Thanks for researching that for me! A
Will do. Thanks again.That collar is there to prevent the bearing from walking off the shaft by doubling the surface area that has a press fit. Also, I have had mixed luck getting the seal to reseal after being removed. I would try to get the shop to replace the whole set, and not just add the collars.
The retainer ring is a harder press fit than the bearing, if I remember correctly from doing mine.
The ring is a one time use item, you drill it part way and split it with a punch to remove it in order to not nick the shaft and cause a stress riser where it will break under load. It should have been in the kit.
The seal usually will leak if it is reused, in my experience.
By using the RTV do you think I will be good with not having to cut off the bearing and replace the seal that was literally just installed one mile ago? Do you think I could just install the Ring?Clean the seal good and coat it with RTV Black just before you bolt the flange up. Even on new installs we do this.
Some people have mentioned the seal being a one time use only, which would mean I'd need to cut the bearing off in order to replace it. Just wanted to confirm I could reuse the seal?He's just speaking from a preventative point of view. You should be able to install the inner retainer without messing with the bearing at all. It will require a press though.
That's what I was thinking. The RTV is a good tip, though! I'll buy the inner ring and press it on tomorrow. Thanks guys!I have reused seals with no issues myself. I know techs that will replace it everytime just to be safe. IMO, with such a short time on the new one, you should be fine reusing it.
I do have a press. Thanks for the help!You can also heat the ring up and drop it on, IF you don’t have a press. This works for the bearing as well but preferably with an induction heater.
