jeepsheets
Had to put front and rear seal replacement on hold as I appear to have popped a radiator yesterday... will pressure test to confirm, but based on loss of coolant and initial inspection of hoses, pretty sure the plastic top cracked.
It’s a ‘90 YJ with 6 cyl. 180k miles. I plan to keep it for quite a while if I can afford to... Question is this, should I go aluminum with the radiator or stick with stock? No serious off roading, just a big mud hole here and there. Mostly just a fun drive around Jeep.
I’ll be doing this work myself, so any advice/thoughts appreciated.
Thanks.
Thanks.
