JKEmmy
Hey guys, picked up a pair of metalcloak quick disconnects. I currently have a 3.5in aev lift with the geometry kit installed. The geometry kit has a set of brackets that lower the control arms and keeps the track bar in the proper position and so on. The brackets also moves the sway bar links up to use the stock bars. These metalcloak bars are adjustable but they don't go that short. The driver side I can just remove the bracket. But the passenger side is one bracket for track bar and the steering stabilizer as well as the sway bar link. My idea is to drill a hole at a lower point to install the quick disconnect. My concern is if it will be an issue with it down inside the bracket a bit. The sway bar links shouldn't have any side to side play right? I posted a picture here to show my idea and the bracket. Thanks everyone!
