RageKage
Posted this on the alignment write up but thought I'd bump it here with my other questions.
My question for alignment is which step do you start first? Toe-in is last but would you center the axle or center the steering wheel or set caster first?
Also being that I have a 6.5 inch lift what do I need to set my pinion angle at to avoid driveline vibrations? Seems like my caster would need to be well over to compensate. Or should I just get a slip yoke eliminator when I get a new front axle?
Looking at the Adams 1350 front driveshaft btw if that helps any. Currently not running a front driveshaft cuz I still had the stock one on and it was about to shear itself apart so I removed it to prevent further damage.
For the locker portion I read somewhere that an electronic locker on my 2014 JKU is a no go because it will send the jeep into limp home mode due to the traction control and other sensors going haywire from the electronic locker being engaged. Is this correct? I've been looking at ARB lockers anyways just wanted to know if this info was correct or do I now have some more options to consider.
Thanks guys, you all have helped increase my knowledge and understanding tremendously since joining.
