JKAnimal
So I had my Jeep up on Jacks a week or so ago and while I was under it I noticed a wet spot. After closer inspection it seems to be leaking transmission fluid at a fairly slow rate where the tranny connects to the transfer case. My question is; could taking a hit to the cross-member that helps support the transmission cause a leak of this nature? Could it just be loose bolts? :thinking:
When we went to CO this Sept. I took a hit on the resonator (muffler looking thing) that sits right under the back door. It yanked/bent the exhaust at the engine mount and I had to replace the exhaust loop and cat converter ($800). I am now going to assume that this also caused the damage to the cross member. Unfortunately there was no turning around on the trail or bypass as we were on the Upper Reno portion of Reno Creek. :crazyeyes:
I just wanted some educated opinions before going to the dealer. Thanks in advance!
See pics :doh:
See pics :doh:
