CapnMericaMyCopilot
Hey guys, I’m considering picking up a few of the Lux rock lights but was wondering if I’d be able to (‘easily’) set one or two per side to come on when I lock/unlock the vehicle. Basically how the dome lights do... is there a fuse I can tap into? I know with my previous headlights I tapped into a fuse so the halo would come on with lock/unlock but I believe it was tied to the ignition and I rather not drive around with the rock lights constantly on.
I’m just trying to figure out quantity at this point. My thought is one / wheel all controlled together. Plus the 1or2 at each side below doors switched together to work as described above. If I got an 8 piece set I may put one at front / rear bumper or just under the hood to a separate switch as well.
I reached out to them to see if it’s possible to set up something like this with the Bluetooth controller/app as opposed to wiring/fuses but didn’t get an exact answer. Exploring the app itself I can’t find an answer either. Has anyone used the Bluetooth option from them? Adds quite a bit to cost...
