GoMopar440
So, I'm mounting a winch upside down so that it hides inside my stock bumper. FWIW: It's a HF Badlands 12K winch on a modified Badlands universal winch mount plate. From reading posts on the forum here, I already knew that I would have to relocate the vacuum pump and bracket to allow the Winch to clear. My issue is the fact that I found my Vacuum pump to be corroded to the point that the Hose nipple has fallen off and the remaining hole in the pump is plugged up with corrosion.
I obviously need a new vac pump, as well as a relocation bracket, but my question is: Will the open vacuum system cause any issues with the braking system? My brakes do seem to be operating fine at the moment. The broken/corroded hose connection looks like it's been separated from the vacuum pump for quite a while.
