Question about adding a Rubicon front locker.
Scottyjeep76
So I have an O8 Jk that came with the True-loc rear locker and sway bar disconnect.
My question is, can I and a Rubicon 44 with stock locker and wire it up to the same "axle lock" switch that's already I the Jeep?
If yes does anyone know what wiring harness I would need for that?
Thanks in advance guys!
I believe you can. You should be able to bypass it and run directly to a switch
You can, I have mine running directly to a rocker switch.
There's a part number for the harness that I used, I'll see if I can find it for you.
There's two different harnesses, one has the swaybar disconnect and other things hooked up, another is just the plug for the locker.
Assuming you are just after the plug?
This harness will plug right into the oem style locker and be long enough for the rear.
Mopar PN: P5155359
Man, you have a unicorn there. Like an 07 with a D35 rear....
I'll have to pull it apart to look, but if possible I'd like to use the stock switch like on the Rubi's.
So I think I'll need a new harness for that to work.
You use the same harness, you just wire it to the rubicon switch instead.
I don't have a rubicon, I just swapped axles hence why mines hooked to a different switch.
** Tgoss linked the part number I was referring to.
