hyvltge
Has anyone else noticed their engine coolant temperature being higher then normal after installing the PSC Tranny and Power Steering radiator?
The cooler has lowered my transmission temps greatly but since the install I feel like my ECT has been way to high.
Probably doesn’t hale that I have the wild boar grille which has shorter slots the the stock grille which technically limits the air flow some.
My winch sits plenty low so I don’t feel like that has anything to do with it.
I just installed the Mishimoto upgraded radiator last night which gives you 60% more cooling capacity as well as the 185 degree Mishimoto performance/ Racing thermostat. I’ll be out on the highway this afternoon and I’m hoping to see some lower temps from the install.
My main question for this topic though is: if you have also installed the PSC cooler that I have, did you notice you ECT temps being higher then normal?
