How much fluid does the system take? I will be running a dual pass heat sink 14" along with it
Are you using the stock reservoir or PSCs? The PSC will hold more power steering fluid. Also you may want to have a overflow tube connected to it. They will get hot and overflow.
PSC reservoir. Is there a good base to start off with? I'm ordering online and wanna make sure I get enough and then some.
Alright thank you! Yeah I ordered the 14" heat sink cooler and will have it mounted in front of the radiator
I had the same one. It wasn't effective and I upgraded. Mine is less than 3 months old. I can sell it to you. Cancel your order. Personally I'd get the bigger one.
Which one did you go with?
