TND333
As I’m sure you’ve seen, I’m in the process of Upgrading my Jeep and Selling everything underneath as a package for someone looking to upgrade their stock JKU. I’m located in Merced, CA. Everything is off and ready to go.
I have it listed around the internet for more, but the WAL price is 10k for everything. I would prefer to sell it as a group, but let me know if your looking for parts and pieces and we can talk about price.
Dynatrac ProRock 44 ultimate hoisting with 1/2” thick axle tubes and castor corrected end forging. ARB locker, 5.13 gears, RCV axle shafts, synergy ball joints, lube locker gasket. Ram mounts already welded on to axle and track bar. Approximately 10,000 miles.
Dynatrac ProRock60 semi float rear axle. 5.13 gears, ARB locker, raised track bar bracket. Approximately 5,000 miles.
Dynatrac pro grip big break upgrade added to both axles less than 400 miles ago.
Coast 1310 front drive shaft with T-Case adaptor.
Adams rear drive shaft 1350
5 set of 37x13.5R17 Nitto Mud Grapplers with 90% tread. Around 3,000 miles on them.
5 set of ATX Slab bead locks 17”x9” wheel with 3.5” backspacing around 3,000 miles on them, great shape.
JKS sway bar disconnects
Fox 2.0 rear shocks
Synergy/Poly Performance 4.5” dual rate coil springs.
Synergy drag link
Front rock crawler solid adjustable lower control arms
Extended bump stops and other small parts I’m forgetting. (I can even include the driver front shock if that’s what your into)
Fox 2.0 rear shocks
Synergy drag link
