2007 JK Sahara with 102,000 miles. I have done rear pads before on it with no issues, and i have replaced front pads and rotors before with no issues. Today i was working on putting new rotors and pads on the rear. I bought Wagner OEX pads part# OEX1274 which matches my vehicle. For the rotors i went with Brake Best Select part#780519RGS. Both of these came from O'Reillys and i verified they matched. Ii removed the entire caliper assembly from the rotor by removing the 2 18mm bolts which is what I normally due when I do pads. I had to back off the parking brake adjustment a bit to get the rotor off but no real issue there. I put the new rotor on and then depressed the piston on the caliper with a c clamp until it was completely flat. I installed both pads in the caliper and was ready to reinstall the assembly back on the rotor when I ran into an issue. The caliper assembly would not go back on. The front pad (the one that is fixed and doesnt move on the piston) was resting flush against the front of the rotor and the rear pad had plenty of clearance since I had depressed the piston fully. With that front pad flush on the rotor, the rear bracket on the assembly that has the mounting holes for the 18mm bolts would not clear the mounting bracket to get the bolt holes to line up. Its like the new pads were too thick or something. I tried every which way I could to get it back on and it just did not seem possible.
I then thought maybe the rotor they gave me wasnt the right one, so I put the old rotor back on and tried to put the caliper assembly on with the new pads and had the exact same issue. Then I thought maybe the rotor wasnt completely pushed on the hub but I couldnt see where it could be pushed on any further as the base of the wheel studs was showing flush with the holes in the rotor. After fiddling with it for an hour and cussing myself, I gave up and just put the old pads back in there as they still have a little life left and put them on the old rotors as I didnt want them on the new rotors.
What am I missing? The pads dont seem overly thick and I have used Wagner pads before. I verified I installed them correctly I just cant figure out why that caliper wont go back on. It just didnt seem possible.
Any help is appreciated and sorry for not posting pics. My hands were covered in brake dust and I didnt want to get it all over my phone.
