Depends on how you order it. If you order it with factory brackets, then yes you will armour them the same as a factory axle. If you order it with something like EVO high clearance brackets then the will already have been beefed up
I ordered mine through EVO, they installed their skids. Worth every penny so far. The pr44 gives you confidence to go over tougher stuff and you will hit the lca brackets.
Call them directly....WAY more than 12 options! They can customize that axle to fit your every desire. Exact axle width, adjust the pinion angle by rotating the control arm bracket mounting point based on lift height. Your choice of lock out hubs, EVERYTHING is customizable!
