Not sure I would drive to ore from Illinois. (Are you in Arizona or did that not happen)
There is probably a shop closer to you that is an EVO dealer that would know how to install it.
Didn't happen still stuck in Illinois, was thinking road trip out and fly back,making pit stops in Oklahoma and Arizona to visit friends. Honestly I don't have a lot of faith in the couple of shops I know of and have seen work from out here
To be clear, the "Double D" is a long arm kit and the "Double Throw Down" or DTD is the coil over kit with bypass shocks. They are two separate things. Depending on what you're wanting to do, it might make more sense to install the Double D long arm kit and get the DTD front towers and rear EVO lever but run it with single coil overs only. When you can afford it, add in the bypass shocks later. Leaving them out for now will save you a lot of money and installing them later will require no modifications - just bolt them in.
In that DTD setup with only a single coilover up front, the bumpstop is deleted correct? How rough is the bottom end of travel without the bumpstop. I'm kicking around this idea, but not sure I like not having a BS.
I ran the DTD minus bypass configuration for about a year. I did have the rear air bumps. To me it was a probably a bit softer than the bolt on setup but I had not issues the stopped the show. If pushing hard (read too fast) the rear would rely on the air bumps quite a bit especially with any load.
Let me know if you have more questions.
Thanks for the feedback. But just so I understand, no bumpstops were in the front right?
Were you running the lever setup in the rear with the single coilover as well?
If a guy was to go with the double d pro setup is there a difference in the length on the coil overs or would you be able to incorporate those at a later time into the dtd setup
