Hi guys
I am on my second jk just got a 2015 jk u sahara after having owned a 2007 for some time
It has 130000 km on the clock or about 60k miles
I live in dubai so a bit hot around 105 110 f on a normal day
When driving int he road i see temp needle is pointing in the middle and i have been monitoring the evic coolant temp it goes from between 208f to 220 at times even and then 210-215 once i hear the fan kick in . Needle never moves further than middle on tarmac driving
Last couple of times i went desert driving or beach dunes driving i noticed that needle moves a bit higher than middle and coolant temp can get to 230 or 233 f till i hear fan high speed and then coolant tempt drops off. This is with 4h and sand beach driving
Today in the desert it got to 230.235 and it even reached 240 f i could hear the fan working and it then started cooling the coola t temp but this tome i saw the needle closing more on the 3/4 line which worried me a lot
The 07jk temp needle never ever moved from middle at all even in desert but i know the pentadtar tends to work hotter. Having said that i dont know what normal temp looks like in the pentastar and frankly seeing the needlesl today at 3/4 almost worried me as it cqnt be normal
Never ever have i seen the 240s on tarmac other than only when i offroad i see the needle a bit off kiddle but coming down once 233 f is hit max
Can you please help me understand if this is normal or if not normal what you think it could be and how to troubleshoot?
I can hear fan defo kicks in so it does work but the needle moving post middle for me is just not feeling right
