jscribn1
I need some help! I'm getting the PO6DD code on my 2012 3.6l which is the oil pressure code for the 2 stage oil pump. I can clear the code and go almost a day before it comes back and limits me to 3500 RPM or less. I have searched the internet and this site and need to see who has had this issue and the fix? I have purchased a MOPAR oil filter as suggested and the engine oil level is perfect. I'm reading it can be the filter, pressure sensor, the oil pump or the O ring on the oil pickup tube in the pan. I was thinking about doing the sensor first as it's the cheapest part although the labor is over $200 due to the location of the sensor under the intake! Poor design for a part that may need replaced at some point. If the sensor doesn't work then what? Any and all suggestions would be appreciated as I have a trip planned for Sedona in early January. Thank you
