t0fudelivery
Just got home from Walmart and got two sets of Platinum Burners (4 lights total). I plan on using the Project JK writeup for installing two, and find a location to install the other two in the middle. On a scale of 1-10 with 10 being an electrician, I am about a 4-5.
But first I have a few questions:
My first question is directed towards Eddie:
1) I did a search on the forum here and saw you had installed two in the middle of Moby, where exactly did you mount them and did you tap into your line for the front lights behind the grill? Or did you have to run a new line to the positive terminal of the battery?
2) I was thinking of wiring them up to my interior lights so when I unlock the car, they will turn on and act as puddle lights. However I don't want to have to turn on the cabin lights for them to switch on when Im wheeling, so...Is there a way I can have them tapped into the interior lights (with the fade in/out) AND have an auxiliary switch to turn them on with the interior lights off?
3) If this idea is possible, anybody have an idea which wire I can use for the cabin lights and where its located?
Any suggestions?
Any suggestions?
