LaSkyWkr
On my 68 Jeepster, I have a soft top from Best Top...and the windows are permanently attached...so I roll safari style most of the time...unless the top is down or it's too cold.
With all of the rolling up and down...the back window ended up with a 6 inch break. I started with clear tape to stop it from getting worse...but I just did NOT like it...and not worth replacing the entire top.
I tried an 'As Seen On TV' product...the repair could have been cleaner...but I still like the outcome much better than the tape.
If I had to do it again (likely To happen)...I would probably practice on something else first...and put clear tape on the back side...apply glue to the front...push the pieces together...wipe excess away...THEN apply the light to activate the glue.
Anyway...just wanted to share.
