BlackDiamondBound
Time to hit the easy button and get some opinions. I have changed u joints countless times and all has been well except for this go around! this is on a 1310 tom woods double cardan cv front shaft.
Swapped out all 3 joints like I normally do for routine maintenance, bolted the shaft back up. 4wd on flat ground all is good, but once there is pressure on the shaft like going up a hill I got this awful metal sound like taking two screw drivers and hitting them together. So I took it back off; for whatever reason it looked like the cardan was hitting the weld yoke on 1/2 a rotation and the ujoint cap on the other 1/2 of rotation. so I took it all apart, and flipped the cardan around just in case it was directional or balanced in a particular direction, and bolted it all back up.
this go around the original noise was gone but I get this! http://youtu.be/qwd-vopWjj4
I would guess the squeaking would be from the cv socket yoke but i greased it before putting it all back in. the last 4 seconds of the video im not even on the brakes just rolling to a stop.
