U upnover Member May 17, 2014 #1 I am trying to get my pinion angle correct. Right now I am about at 5*, this takes into account my garage slope. Does this look about right. I am about at 4" of lift.
wayoflife Administrator Staff member May 17, 2014 #2 upnover said: I am trying to get my pinion angle correct. Right now I am about at 5*, this takes into account my garage slope. Does this look about right. I am about at 4" of lift. View attachment 83381 Click to expand... Can't see the pic but if this is the rear with a new u-joint style shaft, you want the pinion in line with the drive shaft. If this is a front shaft, you need to set your caster and not concern yourself with pinion angle.
U upnover Member May 17, 2014 #3 This is the front. So you set caster in by placing the angle finder in the front of the pumpkin on the two circles on either side to get a reading?
wayoflife Administrator Staff member May 17, 2014 #4 upnover said: This is the front. So you set caster in by placing the angle finder in the front of the pumpkin on the two circles on either side to get a reading? Click to expand... This write-up I did should help you out: http://wayalife.com/showthread.php?...nt-End-Alignment&p=42391&viewfull=1#post42391
