Installing dynatrac ball joints and had a hell of a time getting the drivers side axle shaft out. I needed to use a pry bar and definitely took some effort. This ring/seal came out with the shaft and not sure what it is? Looks mangled and want to know if I need it or need to replace it? Inner axle seal?? I’m pretty positive it wasn’t on the shaft when I installed these ten factory shafts over the winter. So the shaft is still out (ball joints went in easy), and waiting to hear what I should do about this. The shaft will not slide back in easily at all right now. Help!?
