Tree Frog
Could someone please tell me if there is an easy way to remove the parking brake cables.
I want to get the little S hooks out of the backing plates so I can try to reroute the cables underneath the cross member. They are laying hard on the fuel filler neck and lines just at ride height and I can just see them ripping the filler neck off the tank with as much drop as I have now.
I guess I could try to pull everything apart and back the tension off as much as possible then try it. However knowing you guys there is some easy way to do this without having to totally disassemble my rear brakes.
Thank you.
Thank you.
