Devallee
So the jeep has been slightly overheating for a while now. I say slightly because it gets to 1 click below 3/4 and stops. Never goes past that point no matter how long I leave it running. I had a leak coming from the thermostat housing because I bent it tightening the hose clamp too tight. I replaced the thermostat and housing and it's still doing it. The fan is on and kicking (although I'm not sure exactly what point it's kicking on at). I can't find any leaks coming from everywhere; the coolant level has been at the same place for a while now. Any other things I could check to see why it's doing this? I did change the radiator a while back and I feel like it's been doing this since I replaced it. Could that be the issue? What about the radiator could cause the heat issue? Any ideas would be helpful. Thanks in advance
