Yes Eddie that is one of its purposes so it does not pressurize
No, that is its primary purpose.
...and not allow water in.
What? You'll forgive me but that is just really bad information. The breather does not exist to prevent water from coming in - the tube is extended as high as it does to prevent water from coming in but that is not the same thing.
But if you overfill you can get a higher pressure then what is normal because you have a big man in little suite trying to get out! Small hole and thick oil.
I can't count how many times I've been on trip where a lot of highway miles were involved and had someone spraying out gear oil out their breather tube because they just bought a new aftermarket diff cover and filled it up to the fill hole - easily 3 quarts. Almost every single time I have seen this, there was no gear oil coming out the axle seals. The only time I have seen it leak from the seals is if they were bad or if the axle housing were bent.
Yes aftermarket dust seals.
In other words, you could of had gear oil leak into your axle tubes during the install of your RCV's and then in the process of driving around, it leaked out of outer seals. Once everything worked itself out, you had no more leaks. OR, you still have a bad inner seals but now that you are running the correct amount of gear oil, the outer seals you have are enough to keep what leaks out, in.
Yes stock axle 1.35 qt. recommended. I probably had two plus in mine! Again big man in a little suite!
Makes no difference if so long as your breather tube is unobstructed.
I just asked him if he serviced it since he did not state that hence the question!
You'll forgive me but, you only asked that so that you could tell him, "if you overfill them they will leak also and or push oil even out the vent tube!"
Not trying to inflame you prostate but since when does everyone bend there axles?
Not trying to inflame you but, do you ever wheel your Jeep?
Maybe you should ask him that also along with did he just service his front axle! It could be that simple or that major! Just trying to help the guy!
Just because you don't like what I'm saying to you doesn't mean I'm not trying to help the OP by trying to correct the inaccurate information you are posting.
