Opinions on these shocks?
pastorwug
2.5" King shocks with res.
At $1572. for a set of four and built by King for ORE they should be good but I haven't seen any rigs with them on.
Yes, they're expensive retail but I have the opportunity to purchase a set with a 4" plush coil short arm lift from a guy for $1400
King are known for being some of the best shocks you can get. They're expensive, but worth it if you have the money.
I'm probably going with Fox with resovoir just because the King shocks are too expensive for me.
<img src="http://wayalife.com/attachment.php?attachmentid=56657"/>
I'm running that exact same setup ! You will love the ride! On my fronts I had to rotate the resi over a bit, my tires rubbed a little bit when I was aired down. The rears are a tight fit...
Look,at it this way you are half way to the Double Through Down with these. I agree with Eddie you cannot go wrong with these.
