I've owned both. The twin is a little faster but the single does just fine. On a JL, as long as you have the gas engine, Eddie's ACM bracket makes a clean set up:I have been looking into installing an arb compressor onto my jeep. But I cannot decide between the twin pump or the heavy duty single pump. I would mainly use it to air up my tires after a trail ride. What would you guys recommend?
wayalife.com
That would look really clean. I just looked it up, those ports aren't all that expensive either.I was actually looking at running the air chuck to the drivers side cowl and using a 4xe charging port piece to mount the switch and chuck. I was looking at the bracket from Eddie as well.
That’s bad ass.Hoping to make something like this.
great idea, I've been considering installing an ARB since my Co2 tank while fast, it's become a real PIA to get filled, takes up valuable space and now due for a pressure test but can't find a place that will do it.Hoping to make something like this.
It should. There isn't a difference in the cowl unless you have a 392.great idea, I've been considering installing an ARB since my Co2 tank while fast, it's become a real PIA to get filled, takes up valuable space and now due for a pressure test but can't find a place that will do it.
wonder if that cowl part would fit a 2018 JLU
Not according to multiple people in this threadArb twin is the only way to go
If you have big tires it isNot according to multiple people in this thread![]()
I dunno, I've been airing up my 40's and 42's with a single for quite some time now.If you have big tires it is
I dated a twin once. I got confused and ruined the relationship. So I will probably stay with the single.Arb twin is the only way to go
Agreed.I dunno, I've been airing up my 40's and 42's with a single for quite some time now.
As long as you don't try to have sex with the air compressor.... you should be fine.I dated a twin once. I got confused and ruined the relationship. So I will probably stay with the single.
I no it will work but it sure takes a long time.I dunno, I've been airing up my 40's and 42's with a single for quite some time now.
Do you have something more valuable to do with your time? Like splitting the atom, cold fusion, or something like that?I no it will work but it sure takes a long time.
