2013rubirick
So i have a 2013 jkur and i have a powertank now but with 37's it goes empty to fast so im looking to do on board air, but for a 2013 there isnt a kit i can find for it... so what should i do??
I was thinking same thing bc need a project...and wanting to fill my 2nd Daystar switch panel!!! Quadratec has an exclusive onboard system but its 500 without tank and 6 with so pricey. Viair has a few too in 350-400 price point which quad said they WD recommend....with tank. That's is what I would do. We are local...CD help each other out
And you mount the tank in the trunk
ones i saw just put tank under the hood so you don't lose space anywhere else. pretty neat
Viair makes a tank mount but its a horrible location. You can mount a compressor under your hood and run from that. It'll take you around 3 minutes per tire
Where exactly do you mount the compressor at under the hood does someone make a mount. The one from viair says it doesnt work one 2013 models
That's what I have. That's what will take 3.5 minute to air up your tires.
Have you ever though of adding a tank. Or do you think its not needed
I found this i think im gonna get it http://www.amazon.com/Dominion-OffR...qid=1384147012&sr=8-4&keywords=jk+onboard+air
