Which on-board air system will fill 37" tires fast? & how long is it taking u?
u prob have a york compressor. co2 is fast as hell too. powertank makes some nice kits but they are pricey. u can put one together for much less
We run the ARB twin air compressor.
I run an ARB twin as well and it's pretty sweet. Makes short work of filling tires. I mounted mine in the cargo area.
I have the same twin compressor but haven't installed it yet what's underneath it some kind of box that you installed to mount the compressor and where is your air tank at
Here is mine... Overall of the tank,
Output and input of air..
Air gauge up front
Trunk with latch closed...
Can this compressor be mounted to the roll bar in the rear?
- aaron
Sent from the WAYALIFE app
Wow. Great setup.
Thanks it took us roughly a week to install only because it took two days to weld the box together / paint...the rest was just taking our time to make it as clean as possible. Very important thing to remember is when drilling through the subwoofer box... don't forget to remove the sub itself and patch the holes with the proper silicone.. otherwise it'll sound like....:icon_crazy: I will be adding a second ARB high output compressor to maintain a higher output of air to maybe be able to use power tools after putting a higher solenoid than 100lbs of air on the tank...
