There's really nothing special about doing an oil change on any vehicle but being that I was doing one on Emma, our 1969 C101 Jeepster Commando, I figured I'd take a few shots and make a post about it just because. Certainly for those of you who've never worked on old iron like this, you might enjoy seeing how so little has changed over the years. Also, a few of you might not know it but back in the day, a lot of Jeeps were manufactured with motors that weren't made by Willys, Kaiser or AMC. In fact, the 225 Dauntless V6 under Emma's hood was actually made by Buick. Anyway, here are a few shots that I took while changing her oil, I hope you enjoy
Here's a shot of everything needed to change the oil on a Jeepster Commando with a Dauntless V6. I make that note because some C101's did come with a 134 F-Head Hurricane I4. As you can see, this old motor still likes a nice heavy 15W40 and the WIX 51258 filter was readily available at my local O'Reilly's auto parts store.
I already had Emma racked up as I was doing a routine inspection so I used the opportunity to service her as well.
Using a 9/16" socket to remove the drain bolt.
Draining her pan of the black stuff.
Using a 9/16" socket to reinstall the drain bolt.
It's kind of nice that the 3.6L Pentastar that comes in modern Jeep JK Wranglers use a cartridge filter that gets installed at the top of the engine but back in the day, a canister filter was attached to the side of the block and a filter wrench was needed to remove it.
Carefully removing the old filter and allowing the remaining oil to drain out.
Applying just a smear of old oil to the rubber gasket on the new WIX filter to give it a bit of lubrication for installation.
Installing the new WIX filter to a nice solid hand tightness.
Pouring in a fresh 5 quarts of oil back into Emma's engine.
And that's all there is to it. Again, nothing special about this post but I hope you enjoyed it just the same
