Tumbleweed
Because of sagging issues, I've just changed the rear springs from my 3" lift to 4.5" Unlimited.
I now need some rear adjustable control arms to rotate the axle up to better align with the transfer case.
I was told that I need to be aware of the possibility that the pinion bearing might suffer from oil deprivation due to the increased angle.
Question: How much is too much angle? How do I keep the oil up at the bearings long enough? Some type of slinger & baffle combination?
Here's a pic of my angles on the stock control arms and drive shaft. Both will get changed shortly.
