what ever you do dont buy the knock offs like my buddy here did.
ha ha , sucker!!
I run Combat LED. They are slightly more affordable than Rigid, and I believe they are a better, brighter product. I have seen them side by side and found on early mornings the Rigid had all sorts of dew/moisture inside the lens and housing,, that equals water sitting on your electronics!!! The Combat LED was dry as a bone! Also,, the brighter isnt just a claim. Combat is actually running higher power to every LED, which equals brighter light.
Moisture has nothing to do with manufacturer. It has a bad seal if there is moisture. It's an easy fix.
A seal on a light fixture has nothing to do with manufacturing!!! That makes no sense!!:thinking:Moisture has nothing to do with manufacturer. It has a bad seal if there is moisture. It's an easy fix.
